Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement
  1. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement, Line: step 1, image 1 of 1
    • To prepare a new line for your weed whacker, use your utility scissors and cut a piece of line between 30 cm and 50 cm long.
  2. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 2, image 1 of 1
    • Press the buttons on the opposite sides of the trimmer cover and lift it off the head of the trimmer.
  3. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 3, image 1 of 2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 3, image 2 of 2
    • Remove the spool from the trimmer head.
    • Be careful when removing the spool as the line is still being fed through the access hole.
  4. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 4, image 1 of 2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 4, image 2 of 2
    • Remove any remaining pieces of old line by sliding it out of the space it sits in.
    • Insert the new line into the opening.
  5. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 5, image 1 of 1
    • Wrap your line around the spool and make sure you leave 10 cm of the line loose.
    • There are arrows on the spool indicating which direction to wrap the line.
  6. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 6, image 1 of 1
    • Insert the end of the line into the metal hole.
    • Feed about 10 cm of line through the hole.
  7. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 7, image 1 of 2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: step 7, image 2 of 2
    • Place spool back in place and snap it into place.
    • Place the cover back on the head of the weed whacker.
Camille Guzman
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 93
All Time: 919
