Bissell SpotClean ProHeat 5207U Float Gasket Replacement
  1. Bissell SpotClean ProHeat 5207U Float Gasket Replacement, Float Gasket: step 1, image 1 of 3 Bissell SpotClean ProHeat 5207U Float Gasket Replacement, Float Gasket: step 1, image 2 of 3 Bissell SpotClean ProHeat 5207U Float Gasket Replacement, Float Gasket: step 1, image 3 of 3
    • Ensure the device is unplugged.
    • Position the device so that you can see the text at the bottom saying "SpotClean ProHeat."
    • Remove the dirty water tank located to the right.
    • The tank should read "dirty" on the inner edge.
  2. Bissell SpotClean ProHeat 5207U Float Gasket Replacement: step 2, image 1 of 3 Bissell SpotClean ProHeat 5207U Float Gasket Replacement: step 2, image 2 of 3 Bissell SpotClean ProHeat 5207U Float Gasket Replacement: step 2, image 3 of 3
    • Rotate the bottom of the flow stack counterclockwise until the float stack comes loose.
    • Remove the float stack from the tank.
  3. Bissell SpotClean ProHeat 5207U Float Gasket Replacement: step 3, image 1 of 3 Bissell SpotClean ProHeat 5207U Float Gasket Replacement: step 3, image 2 of 3 Bissell SpotClean ProHeat 5207U Float Gasket Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers carefully remove the white O-ring.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 84
