Bissell Pet Hair Eraser Motorized Brush Belt Replacement
  1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: step 1, image 1 of 2 Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: step 1, image 2 of 2
    • Turn power OFF.
    • Detach motorized brush from the vacuum.
  2. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 2, image 1 of 2 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 2, image 2 of 2
    • Use a spudger or a coin to turn the circular lock clockwise to unlock the brush roll.
    • Remove the lock cover.
  3. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 3, image 1 of 1
    • Lift brush out of the enclosure.
  4. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 4, image 1 of 3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 4, image 2 of 3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 4, image 3 of 3
    • Remove the four 13.0 mm Phillips #0 screws and remove the green cover.
  5. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 5, image 1 of 1
    • Take out the motor assembly.
  6. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush Belt: step 6, image 1 of 1
    • Take the belt off the gear by using a spudger.
  7. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 7, image 1 of 3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 7, image 2 of 3 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: step 7, image 3 of 3
    • Grab the new belt and slide it on to the two gears.
    • Place the motor assembly back into the motorized brush enclosure.
To reassemble your device, follow the motorized brush disassembly instructions in reverse order.
Roman Dyagilev
217 Reputation
2 Guides authored
IUPUI, Team S4-G4, Wilson Fall 2017 Member of IUPUI, Team S4-G4, Wilson Fall 2017
IUPUI-WILSON-F17S4G4
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 412
