Bissell Pet Hair Eraser Motherboard Replacement
  1. Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: step 1, image 1 of 2 Bissell Pet Hair Eraser Motherboard Replacement, Dirt Cup: step 1, image 2 of 2
    • Firmly grasp the handle and press the release button.
    • Gently pull the dirt cup down and away from the vacuum body.
  2. Bissell Pet Hair Eraser Motherboard Replacement, Power Button: step 2, image 1 of 2 Bissell Pet Hair Eraser Motherboard Replacement, Power Button: step 2, image 2 of 2
    • Remove the six 1.2 mm Philips #2 screws from the handle and base.
  3. Bissell Pet Hair Eraser Motherboard Replacement: step 3, image 1 of 2 Bissell Pet Hair Eraser Motherboard Replacement: step 3, image 2 of 2
    • Grasp each half of the body and gently pull apart.
    • The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Once the case is split apart these items may come dislodged.
  4. Bissell Pet Hair Eraser Motherboard Replacement: step 4, image 1 of 3 Bissell Pet Hair Eraser Motherboard Replacement: step 4, image 2 of 3 Bissell Pet Hair Eraser Motherboard Replacement: step 4, image 3 of 3
    • The power button can be removed by gently lifting it off the circuitry.
  5. Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: step 5, image 1 of 2 Bissell Pet Hair Eraser Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Remove the battery plastic hold down by lifting it off the tabs.
    • Remove the battery by lifting straight up.
    • Position the battery aside.
  6. Bissell Pet Hair Eraser Motherboard Replacement: step 6, image 1 of 3 Bissell Pet Hair Eraser Motherboard Replacement: step 6, image 2 of 3 Bissell Pet Hair Eraser Motherboard Replacement: step 6, image 3 of 3
    • Grasp the charger port and remove it by lifting it straight out of the case.
    • Set the charger port next to the battery.
  7. Bissell Pet Hair Eraser Motherboard Replacement: step 7, image 1 of 2 Bissell Pet Hair Eraser Motherboard Replacement: step 7, image 2 of 2
    • Remove the power button and charge LED light by gently pulling straight out of the case.
    • The vacuum motor can be removed by pulling straight out of the case.
    • All internals are now removed.
    • Set the case halves aside.
  8. Bissell Pet Hair Eraser Motherboard Replacement: step 8, image 1 of 1
    • Remove the two 1 mm Phillips #2 screws in the shown locations.
  9. Bissell Pet Hair Eraser Motherboard Replacement: step 9, image 1 of 2 Bissell Pet Hair Eraser Motherboard Replacement: step 9, image 2 of 2
    • Disconnect the power leads from the vacuum motor.
    • The red power lead goes on the terminal with the visible red dot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 366
