Bionaire BAP 600 Transformer Replacement
  1. Bionaire BAP 600 Transformer Replacement, Control Board: step 1, image 1 of 1
    • Unplug 7 pin connector
  2. Bionaire BAP 600 Transformer Replacement: step 2, image 1 of 1
    • Unplug 2 pin wires which connects the front LED's.
  3. Bionaire BAP 600 Transformer Replacement: step 3, image 1 of 2 Bionaire BAP 600 Transformer Replacement: step 3, image 2 of 2
    • Remove two screws
  4. Bionaire BAP 600 Transformer Replacement: step 4, image 1 of 1
    • Unplug pins
    • Use scissors to cut zip ties
  5. Bionaire BAP 600 Transformer Replacement: step 5, image 1 of 3 Bionaire BAP 600 Transformer Replacement: step 5, image 2 of 3 Bionaire BAP 600 Transformer Replacement: step 5, image 3 of 3
    • Unplug rest of pin connections
    • Remove Neutral and Hot wires
    • They are the two black wires
    • Pull them out
  6. Bionaire BAP 600 Transformer Replacement: step 6, image 1 of 3 Bionaire BAP 600 Transformer Replacement: step 6, image 2 of 3 Bionaire BAP 600 Transformer Replacement: step 6, image 3 of 3
    • Unscrew two screws
    • Inspect capacitor for any bulges ( if it has a bulge , it means it is need to be replaced)
    • Check for burnt solder in the back of circuit board
  7. Bionaire BAP 600 Transformer Replacement, Transformer: step 7, image 1 of 2 Bionaire BAP 600 Transformer Replacement, Transformer: step 7, image 2 of 2
    • Use screwdriver to remove screws
Alexander Tarancon
49 Reputation
2 Guides authored
IUPUI, Team 4-4, Baechle Fall 2016 Member of IUPUI, Team 4-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S4G4
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 206
