Besta Super 5000 Motherboard Replacement
  1. Besta Super 5000 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Motherboard Replacement: step 2, image 1 of 2 Besta Super 5000 Motherboard Replacement: step 2, image 2 of 2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Motherboard Replacement: step 3, image 1 of 1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Motherboard Replacement, Back Cover: step 4, image 1 of 1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Motherboard Replacement: step 5, image 1 of 1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Motherboard Replacement: step 6, image 1 of 2 Besta Super 5000 Motherboard Replacement: step 6, image 2 of 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Motherboard Replacement, Motherboard: step 7, image 1 of 1
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Motherboard Replacement: step 8, image 1 of 1
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Motherboard Replacement: step 9, image 1 of 3 Besta Super 5000 Motherboard Replacement: step 9, image 2 of 3 Besta Super 5000 Motherboard Replacement: step 9, image 3 of 3
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Motherboard Replacement: step 10, image 1 of 2 Besta Super 5000 Motherboard Replacement: step 10, image 2 of 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Motherboard Replacement: step 11, image 1 of 1
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Motherboard Replacement: step 12, image 1 of 2 Besta Super 5000 Motherboard Replacement: step 12, image 2 of 2
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
Jessie
370 Reputation
3 Guides authored
Ohio State, Team 1-5, Buehl Fall 2014 Member of Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 13
All Time: 370
