Besta Super 5000 Back Cover Replacement
  1. Besta Super 5000 Back Cover Replacement, Battery: step 1, image 1 of 1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Back Cover Replacement: step 2, image 1 of 2 Besta Super 5000 Back Cover Replacement: step 2, image 2 of 2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Back Cover Replacement: step 3, image 1 of 1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Back Cover Replacement, Back Cover: step 4, image 1 of 1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Back Cover Replacement: step 5, image 1 of 1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Back Cover Replacement: step 6, image 1 of 2 Besta Super 5000 Back Cover Replacement: step 6, image 2 of 2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
Jessie
370 Reputation
3 Guides authored
Ohio State, Team 1-5, Buehl Fall 2014 Member of Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 12
All Time: 290
