Beats Studio 2 Wireless Speaker Replacement
  1. Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: step 1, image 1 of 2 Beats Studio 2 Wireless Speaker Replacement, Ear Cushion: step 1, image 2 of 2
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
  2. Beats Studio 2 Wireless Speaker Replacement: step 2, image 1 of 3 Beats Studio 2 Wireless Speaker Replacement: step 2, image 2 of 3 Beats Studio 2 Wireless Speaker Replacement: step 2, image 3 of 3
    • Pull the rest of the cushion away from the adhesive with your hands.
  3. Beats Studio 2 Wireless Speaker Replacement, Speaker: step 3, image 1 of 2 Beats Studio 2 Wireless Speaker Replacement, Speaker: step 3, image 2 of 2
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
  4. Beats Studio 2 Wireless Speaker Replacement: step 4, image 1 of 1
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
  5. Beats Studio 2 Wireless Speaker Replacement: step 5, image 1 of 2 Beats Studio 2 Wireless Speaker Replacement: step 5, image 2 of 2
    • Gently pull the wire with rubber connectors off of the speaker.
  6. Beats Studio 2 Wireless Speaker Replacement: step 6, image 1 of 1
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
After soldering the new speaker, reassemble your device by following the steps in reverse order.
3 other people completed this guide.
Mike Rosiello
313 Reputation
2 Guides authored
One Comment
I didn't need to replace a speaker but just touch up the solder joints, this was a great guide! Thank you!
William Pryor - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 35
All Time: 316
