Autosampler Configuration for Node Control (For Old & New Versions)
  1. Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: step 1, image 1 of 3 Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: step 1, image 2 of 3 Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: step 1, image 3 of 3
    • 1. Turn on the autosampler. Screen will read "...STANDBY..."
    • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
    • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
    • 3. Use arrows to find "EVENT MARK". Press the "ENTER/PROGRAM" button.
  2. Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: step 2, image 1 of 3 Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: step 2, image 2 of 3 Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: step 2, image 3 of 3
    • 4. Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
    • 5. Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
    • It is critical this setting is configured in order for the sensor node to operate the autosampler!
    • 6. Use arrows to find "EXIT CONFIGURATION." Press "ENTER/PROGRAM" button. This will bring up the screen "...STANDBY...
Finish Line
Brooke Mason
2,928 Reputation
17 Guides authored
Open-Storm Member of Open-Storm
Community
14 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 97
