Asus Zenfone 3 Zoom Battery Replacement
  1. Asus Zenfone 3 Zoom Battery Replacement, Battery: step 1, image 1 of 2 Asus Zenfone 3 Zoom Battery Replacement, Battery: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. Asus Zenfone 3 Zoom Battery Replacement: step 2, image 1 of 1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. Asus Zenfone 3 Zoom Battery Replacement: step 3, image 1 of 2 Asus Zenfone 3 Zoom Battery Replacement: step 3, image 2 of 2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. Asus Zenfone 3 Zoom Battery Replacement: step 4, image 1 of 1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. Asus Zenfone 3 Zoom Battery Replacement: step 5, image 1 of 1
    • Peel back the silver tape.
  6. Asus Zenfone 3 Zoom Battery Replacement: step 6, image 1 of 1
    • Disconnect the battery connections.
  7. Asus Zenfone 3 Zoom Battery Replacement: step 7, image 1 of 1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
5 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 29
All Time: 3,808
