Asus Zenbook UX32VD Battery Replacement
  1. Asus Zenbook UX32VD Battery Replacement, Bottom Panel: step 1, image 1 of 3 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: step 1, image 2 of 3 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: step 1, image 3 of 3
    Tool used on this step:
    T5 Torx Screwdriver
    $9.99
    Buy
  2. Asus Zenbook UX32VD Battery Replacement: step 2, image 1 of 3 Asus Zenbook UX32VD Battery Replacement: step 2, image 2 of 3 Asus Zenbook UX32VD Battery Replacement: step 2, image 3 of 3
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD Battery Replacement, Battery: step 3, image 1 of 2 Asus Zenbook UX32VD Battery Replacement, Battery: step 3, image 2 of 2
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
  4. Asus Zenbook UX32VD Battery Replacement: step 4, image 1 of 2 Asus Zenbook UX32VD Battery Replacement: step 4, image 2 of 2
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
  5. Asus Zenbook UX32VD Battery Replacement: step 5, image 1 of 3 Asus Zenbook UX32VD Battery Replacement: step 5, image 2 of 3 Asus Zenbook UX32VD Battery Replacement: step 5, image 3 of 3
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  6. Asus Zenbook UX32VD Battery Replacement: step 6, image 1 of 1
    • Remove the battery completely.
4 other people completed this guide.
Jenny Nguy
177 Reputation
1 Guide authored
CSU Fullerton, Team 2-2, Bruce Fall 2015 Member of CSU Fullerton, Team 2-2, Bruce Fall 2015
CSUF-BRUCE-F15S2G2
4 Members
6 Guides authored
5 Comments
what is the color code of the battery wiring? especially for the white and yellow
Asim Ahmed - Reply
Will this method also apply to ASUS Zenbook UX430UQ ?
Kurt Scheel - Reply
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
Kurt Scheel - Reply
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Nikolay Em - Reply
Why would you replace the speakers? I don't ever understand, why would you unplug the speakers (as it's done in these instructions)? They are just taped on side of the battery, once you lift up the battery a little bit, you can take the speakers off from the battery pack and leave them on their place while replacing the battery.
Touko Korpela - Reply
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 49
All Time: 17,698
