Asus ROG Strix GL702VS Speaker Replacement
  1. Asus ROG Strix GL702VS Speaker Replacement, Back Cover: step 1, image 1 of 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Speaker Replacement: step 2, image 1 of 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Speaker Replacement: step 3, image 1 of 2 Asus ROG Strix GL702VS Speaker Replacement: step 3, image 2 of 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Speaker Replacement: step 4, image 1 of 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Speaker Replacement, Speaker: step 5, image 1 of 3 Asus ROG Strix GL702VS Speaker Replacement, Speaker: step 5, image 2 of 3 Asus ROG Strix GL702VS Speaker Replacement, Speaker: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect the two sets of speaker connectors using a pair of tweezers.
  6. Asus ROG Strix GL702VS Speaker Replacement: step 6, image 1 of 3 Asus ROG Strix GL702VS Speaker Replacement: step 6, image 2 of 3 Asus ROG Strix GL702VS Speaker Replacement: step 6, image 3 of 3
    • Gently remove the speakers by lifting up.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 28
All Time: 985
