Asus ROG Strix GL553VD Battery Replacement
  1. Asus ROG Strix GL553VD Battery Replacement, Battery: step 1, image 1 of 2 Asus ROG Strix GL553VD Battery Replacement, Battery: step 1, image 2 of 2
    • Use a JIS screwdriver to remove the ten 4 mm screws from the bottom cover.
  2. Asus ROG Strix GL553VD Battery Replacement: step 2, image 1 of 2 Asus ROG Strix GL553VD Battery Replacement: step 2, image 2 of 2
    • Open the flap in the middle to reveal the 11th screw and remove it using the same JIS screwdriver.
  3. Asus ROG Strix GL553VD Battery Replacement: step 3, image 1 of 3 Asus ROG Strix GL553VD Battery Replacement: step 3, image 2 of 3 Asus ROG Strix GL553VD Battery Replacement: step 3, image 3 of 3
    • Gently lift each corner to remove the cover from the laptop.
    • If you seem to have difficulty removing the cover, you may use a plastic opening tool to pry up one of the corners to get you started.
  4. Asus ROG Strix GL553VD Battery Replacement: step 4, image 1 of 3 Asus ROG Strix GL553VD Battery Replacement: step 4, image 2 of 3 Asus ROG Strix GL553VD Battery Replacement: step 4, image 3 of 3
    • Gently pull the white battery connector out towards the battery.
  5. Asus ROG Strix GL553VD Battery Replacement: step 5, image 1 of 1
    • Carefully lift the battery out from the case to remove it.
    • The battery will come off easily as the screws are already removed.
4 other people completed this guide.
Mahmoud Mehdi
247 Reputation
1 Guide authored
One Comment
Thank you for the guide. It was tricky to find the screw in the middle, hidden behind the flap. The screws are however not torx as shown.
Soheil Roshanbin - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 81
All Time: 4,445
