Asus ROG STRIX GL502V Memory Replacement
  1. Asus ROG STRIX GL502V Memory Replacement, Asus ROG STRIX GL502V Lower Case: step 1, image 1 of 2 Asus ROG STRIX GL502V Memory Replacement, Asus ROG STRIX GL502V Lower Case: step 1, image 2 of 2
    • Remove 10 screws.
    • Note: front screws (blue) are 10mm long, central and rear (brown) are 12mm.
  2. Asus ROG STRIX GL502V Memory Replacement: step 2, image 1 of 2 Asus ROG STRIX GL502V Memory Replacement: step 2, image 2 of 2
    • With opening tool or pick go around the case starting from back corner.
  3. Asus ROG STRIX GL502V Memory Replacement: step 3, image 1 of 1
    • Lift cover and now you have access to most of the components.
  4. Asus ROG STRIX GL502V Memory Replacement, Remove memory module: step 4, image 1 of 1
    • Pull spring locks out.
    • Lift module up and out of the connector.
Sergei
622 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 175
