Asus ROG G750JH-DB71 Hard Drive Replacement
  1. Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: step 1, image 1 of 2 Asus ROG G750JH-DB71 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Hard Drive Replacement: step 2, image 1 of 3 Asus ROG G750JH-DB71 Hard Drive Replacement: step 2, image 2 of 3 Asus ROG G750JH-DB71 Hard Drive Replacement: step 2, image 3 of 3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Asus ROG G750JH-DB71 Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Use a pick or your finger to lift up the plastic cover on back of the laptop.
    • Under the plastic cover is a screw, unscrew it using a Phillips #00 screwdriver.
    • The screw has a c lock so it can not be unscrewed completely. Once Its loose pry on the seam using a screwdriver or the iFixit pry tool.
  4. Asus ROG G750JH-DB71 Hard Drive Replacement: step 4, image 1 of 3 Asus ROG G750JH-DB71 Hard Drive Replacement: step 4, image 2 of 3 Asus ROG G750JH-DB71 Hard Drive Replacement: step 4, image 3 of 3
    • Remove the cover.
    • Remove the four 4.0 mm Phillips #00 screws holding in the hard drive caddy.
    • Push the caddy towards the open space in its compartment to remove it.
Devin Medeiros
219 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 133
