Asus ROG G750JH-DB71 Disassembly
  1. Asus ROG G750JH-DB71 Disassembly, Battery: step 1, image 1 of 2 Asus ROG G750JH-DB71 Disassembly, Battery: step 1, image 2 of 2
    • Ensure the laptop is powered off and unplugged before beginning.
    • Flip the laptop over so the bottom case is facing up.
  2. Asus ROG G750JH-DB71 Disassembly: step 2, image 1 of 3 Asus ROG G750JH-DB71 Disassembly: step 2, image 2 of 3 Asus ROG G750JH-DB71 Disassembly: step 2, image 3 of 3
    • Push the switch near the front of the laptop to release the battery from the computer.
    • Pull the battery out and away from the center of the computer.
  3. Asus ROG G750JH-DB71 Disassembly, Asus ROG G750JH-DB71: step 3, image 1 of 3 Asus ROG G750JH-DB71 Disassembly, Asus ROG G750JH-DB71: step 3, image 2 of 3 Asus ROG G750JH-DB71 Disassembly, Asus ROG G750JH-DB71: step 3, image 3 of 3
    • Use a spudger or your finger to lift up the plastic cover on the bottom of the laptop.
    • Under the plastic cover is a captive screw; unscrew it using a Phillips #00 screwdriver.
  4. Asus ROG G750JH-DB71 Disassembly: step 4, image 1 of 2 Asus ROG G750JH-DB71 Disassembly: step 4, image 2 of 2
    • Remove the cover.
    • If your goal is to replace/remove only the hard drive, you don't have to complete the following disassembly steps and can go on to the hard drive replacement guide.
  5. Asus ROG G750JH-DB71 Disassembly: step 5, image 1 of 3 Asus ROG G750JH-DB71 Disassembly: step 5, image 2 of 3 Asus ROG G750JH-DB71 Disassembly: step 5, image 3 of 3
    • Remove the hard drive by unscrewing the 4.4 mm Phillips #00 screws.
    • Remove all of the plastic caps around the edges using a pick or flathead screwdriver, and remove the screws underneath them. (one 13 mm Phillips #00, six 8 mm Phillips #00)
    • Remove the remaining screws underneath the cover . (six 8mm Phillips #00, three 1 mm Phillips #00)
  6. Asus ROG G750JH-DB71 Disassembly: step 6, image 1 of 3 Asus ROG G750JH-DB71 Disassembly: step 6, image 2 of 3 Asus ROG G750JH-DB71 Disassembly: step 6, image 3 of 3
    • You will find a metal tab holding the CD Rom in place. Push on the tab with a flathead screwdriver or an iFixit tool to remove the CD Rom. It is located below a previously removed screw.
    • Do not pull the CD rom out from the side before pushing the metal tab as it will only damage the cover.
    • Remove the three (4 mm Phillips #00) screws that were previously covered by the CD rom.
  7. Asus ROG G750JH-DB71 Disassembly: step 7, image 1 of 3 Asus ROG G750JH-DB71 Disassembly: step 7, image 2 of 3 Asus ROG G750JH-DB71 Disassembly: step 7, image 3 of 3
    • Once the screws are out and the CD rom is removed, the back cover can be taken off by hand.
    • Disconnect the speaker cables located in picture 1 and 2.
    • Remove two 8 mm Phillips #00 screws on each corner shown in picture 3.
  8. Asus ROG G750JH-DB71 Disassembly: step 8, image 1 of 3 Asus ROG G750JH-DB71 Disassembly: step 8, image 2 of 3 Asus ROG G750JH-DB71 Disassembly: step 8, image 3 of 3
    • Pry the keyboard gently using the iFixit prying tool.
    • Make sure to unhook the cables and wires from the keyboard gently in Picture 3.
  9. Asus ROG G750JH-DB71 Disassembly: step 9, image 1 of 2 Asus ROG G750JH-DB71 Disassembly: step 9, image 2 of 2
    • Now you can pull the keyboard off but make sure to do so carefully without damaging or scuffing any components.
    • Pull up and out at an angle to avoid damaging the internals of the laptop.
James Mills
471 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 47
All Time: 451
