Asus Nexus Player Motherboard Replacement
  1. Asus Nexus Player Motherboard Replacement, Motherboard: step 1, image 1 of 3 Asus Nexus Player Motherboard Replacement, Motherboard: step 1, image 2 of 3 Asus Nexus Player Motherboard Replacement, Motherboard: step 1, image 3 of 3
    • Use the metal spudger to gently pry open the back of the Nexus Player.
  2. Asus Nexus Player Motherboard Replacement: step 2, image 1 of 2 Asus Nexus Player Motherboard Replacement: step 2, image 2 of 2
    • Use a PH1 Philips-head screw driver to unscrew the four 8 mm screws holding the shield in place.
    • Once screws are removed, simply lift the shield away.
  3. Asus Nexus Player Motherboard Replacement: step 3, image 1 of 3 Asus Nexus Player Motherboard Replacement: step 3, image 2 of 3 Asus Nexus Player Motherboard Replacement: step 3, image 3 of 3
    • Remove the 5 mm screw using the PH1 Phillips-head screwdriver to be able to remove the motherboard.
    • After the screw is removed, lift the motherboard out of the frame.
Eric Smith
113 Reputation
1 Guide authored
USF Tampa, Team 5-1, Passmore Spring 2017 Member of USF Tampa, Team 5-1, Passmore Spring 2017
USFT-PASSMORE-S17S5G1
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,546
