Asus MeMO Pad 7 ME170C Speaker Replacement
  1. Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: step 1, image 1 of 3 Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: step 1, image 2 of 3 Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: step 1, image 3 of 3
    • Before beginning to disassemble the device, power it off.
    • Make sure to be gentle with the device. Excessive force can result in a damaged screen.
    • Using the Jimmy tool, gently wedge it into the seam of the device at the side.
    • Pry the Jimmy tool gently all around the seam. Use up and down motions until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C Speaker Replacement: step 2, image 1 of 3 Asus MeMO Pad 7 ME170C Speaker Replacement: step 2, image 2 of 3 Asus MeMO Pad 7 ME170C Speaker Replacement: step 2, image 3 of 3
    • From the top of the tablet, locate the white cable connector.
    • It is inserted in a black port on the motherboard.
    • Use the blue plastic opening tool to push the white cable connector out of the port.
    • Push the cable in a sideways motion towards the top of the device.
  3. Asus MeMO Pad 7 ME170C Speaker Replacement: step 3, image 1 of 2 Asus MeMO Pad 7 ME170C Speaker Replacement: step 3, image 2 of 2
    • Use the Phillips #000 screwdriver to remove the seven screws.
    • There should be two silver and five black screws for a total of seven screws.
  4. Asus MeMO Pad 7 ME170C Speaker Replacement: step 4, image 1 of 2 Asus MeMO Pad 7 ME170C Speaker Replacement: step 4, image 2 of 2
    • Use the slender, metal spudger tool to gently lift up the edge of the speaker to remove the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 684
