Asus GL551JW-AH71 Upper Assembly Replacement
  1. Asus GL551JW-AH71 Upper Assembly Replacement, Battery: step 1, image 1 of 1
    • Close the device and lay it upside down.
    • Unplug the device and make sure the device is powered off before removing the battery.
  2. Asus GL551JW-AH71 Upper Assembly Replacement: step 2, image 1 of 2 Asus GL551JW-AH71 Upper Assembly Replacement: step 2, image 2 of 2
    • Move the battery eject button to the right. The battery will be ejected.
  3. Asus GL551JW-AH71 Upper Assembly Replacement: step 3, image 1 of 2 Asus GL551JW-AH71 Upper Assembly Replacement: step 3, image 2 of 2
    • Grab the battery and remove it from the device.
  4. Asus GL551JW-AH71 Upper Assembly Replacement, Optical Drive: step 4, image 1 of 2 Asus GL551JW-AH71 Upper Assembly Replacement, Optical Drive: step 4, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the single 10mm optical drive screw.
  5. Asus GL551JW-AH71 Upper Assembly Replacement: step 5, image 1 of 3 Asus GL551JW-AH71 Upper Assembly Replacement: step 5, image 2 of 3 Asus GL551JW-AH71 Upper Assembly Replacement: step 5, image 3 of 3
    • Insert a probe or paperclip gently into the eject pin hole to eject the optical drive tray.
  6. Asus GL551JW-AH71 Upper Assembly Replacement: step 6, image 1 of 2 Asus GL551JW-AH71 Upper Assembly Replacement: step 6, image 2 of 2
    • Gently grasp the optical drive assembly and slide it out of the laptop body.
  7. Asus GL551JW-AH71 Upper Assembly Replacement, Upper Assembly: step 7, image 1 of 2 Asus GL551JW-AH71 Upper Assembly Replacement, Upper Assembly: step 7, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the two 11mm screws that hold the access panel in place.
  8. Asus GL551JW-AH71 Upper Assembly Replacement: step 8, image 1 of 2 Asus GL551JW-AH71 Upper Assembly Replacement: step 8, image 2 of 2
    • Carefully remove the access panel.
  9. Asus GL551JW-AH71 Upper Assembly Replacement: step 9, image 1 of 2 Asus GL551JW-AH71 Upper Assembly Replacement: step 9, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the seven 11mm screws holding lower case to the laptop.
  10. Asus GL551JW-AH71 Upper Assembly Replacement: step 10, image 1 of 1
    • Turn the laptop over and open the screen.
  11. Asus GL551JW-AH71 Upper Assembly Replacement: step 11, image 1 of 3 Asus GL551JW-AH71 Upper Assembly Replacement: step 11, image 2 of 3 Asus GL551JW-AH71 Upper Assembly Replacement: step 11, image 3 of 3
    • Gently pry open the case with an iFixit opening tool.
    • The upper and lower assembly are connected with a display cable that will be removed in the next step. Do not pull the parts apart more than a few inches.
  12. Asus GL551JW-AH71 Upper Assembly Replacement: step 12, image 1 of 3 Asus GL551JW-AH71 Upper Assembly Replacement: step 12, image 2 of 3 Asus GL551JW-AH71 Upper Assembly Replacement: step 12, image 3 of 3
    • Flip the laptop on the right side while still holding the upper and lower assemblies close together.
    • Unplug the display connector from the motherboard.
    • Remove the upper assembly.
William Kelley
1,035 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 476
