Asus G750JW-BBI7N05 RAM Replacement
  1. Asus G750JW-BBI7N05 RAM Replacement, Battery: step 1, image 1 of 1
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 RAM Replacement: step 2, image 1 of 1
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 RAM Replacement: step 3, image 1 of 1
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 RAM Replacement, RAM: step 4, image 1 of 2 Asus G750JW-BBI7N05 RAM Replacement, RAM: step 4, image 2 of 2
    • Lift up the rubber stopper on the backplate to expose one Phillips screw. Unscrew it until it becomes loose.
    • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the backplate from the laptop.
    • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
  5. Asus G750JW-BBI7N05 RAM Replacement: step 5, image 1 of 1
    • Use an opening tool to pry up the backplate along its edges, then remove it.
    • You may need to apply some force when prying up the backplate.
    • Keep in mind: During reassembly, replace the backplate starting from the bottom.
  6. Asus G750JW-BBI7N05 RAM Replacement: step 6, image 1 of 2 Asus G750JW-BBI7N05 RAM Replacement: step 6, image 2 of 2
    • During the recycling process, this laptop lost some of its parts. In this step, its top two RAM modules are missing.
    • Remove each RAM module one at a time by sliding them downward out of their slots.
One Comment
What about how to remove the other two internal RAM Modules?
Latiron London - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 737
