Asus G501JW-BHI7N12 Cooling Fan Replacement
  1. Asus G501JW-BHI7N12 Cooling Fan Replacement, Cooling Fan: step 1, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
  2. Asus G501JW-BHI7N12 Cooling Fan Replacement: step 2, image 1 of 1
    • Unscrew and remove the four 5mm Phillips #0 screws from the cooling fan.
  3. Asus G501JW-BHI7N12 Cooling Fan Replacement: step 3, image 1 of 1
    • Remove 4 pin connector from mother board.
  4. Asus G501JW-BHI7N12 Cooling Fan Replacement: step 4, image 1 of 1
    • Slide cooling fan out from underneath the copper heat sink.
    • The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
  5. Asus G501JW-BHI7N12 Cooling Fan Replacement: step 5, image 1 of 1
    • One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
Dustin Annis
211 Reputation
2 Guides authored
UW Tacoma, Team 2-1, Rose Winter 2017 Member of UW Tacoma, Team 2-1, Rose Winter 2017
UWT-ROSE-W17S2G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 26
All Time: 2,033
