Asus F555LA-AB31 Hard Drive Replacement
  1. Asus F555LA-AB31 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Remove ten 18mm Phillips #0 screws from the backside of the device.
    • Removal of the RAM access panel is not necessary.
  2. Asus F555LA-AB31 Hard Drive Replacement: step 2, image 1 of 3 Asus F555LA-AB31 Hard Drive Replacement: step 2, image 2 of 3 Asus F555LA-AB31 Hard Drive Replacement: step 2, image 3 of 3
    • Carefully fold the device open.
    • Begin to pry upward on the edges of the faceplate in order to separate the keyboard and trackpad from the rest of the device.
    • Be cautious of the cables connecting the keyboard and trackpad to the motherboard.
    • To remove the ZIF connector, gently lift upward on the blue tab to disconnect it from the motherboard.
  3. Asus F555LA-AB31 Hard Drive Replacement: step 3, image 1 of 3 Asus F555LA-AB31 Hard Drive Replacement: step 3, image 2 of 3 Asus F555LA-AB31 Hard Drive Replacement: step 3, image 3 of 3
    • Fold the keyboard section of the laptop up towards the screen to fully expose the inside of the device.
    • Unscrew the four 4mm Phillips #0 screws holding down the hard drive.
  4. Asus F555LA-AB31 Hard Drive Replacement: step 4, image 1 of 1
    • Disconnect the ZIF connector and lift the hard drive out of the space.
One Comment
Boo, 10 screws in first step are not all the same length, 4 screws in third step are not correctly indicated in the image (nor are they all in view in said image). Finally, there’s a hard drive bracket that is not included in the guide which is important to note how it is positioned to reinstall correctly.
Jeb - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 39
All Time: 1,892
