Asus Eee PC 1215N Keyboard Replacement
  1. Asus Eee PC 1215N Keyboard Replacement, Battery: step 1, image 1 of 2 Asus Eee PC 1215N Keyboard Replacement, Battery: step 1, image 2 of 2
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Asus Eee PC 1215N Keyboard Replacement, Removing Asus Eee PC 1215N Battery Compartment Screws: step 2, image 1 of 1
    • Remove screws on the battery compartment.
  3. Asus Eee PC 1215N Keyboard Replacement, RAM: step 3, image 1 of 3 Asus Eee PC 1215N Keyboard Replacement, RAM: step 3, image 2 of 3 Asus Eee PC 1215N Keyboard Replacement, RAM: step 3, image 3 of 3
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  4. Asus Eee PC 1215N Keyboard Replacement: step 4, image 1 of 1
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  5. Asus Eee PC 1215N Keyboard Replacement: step 5, image 1 of 2 Asus Eee PC 1215N Keyboard Replacement: step 5, image 2 of 2
    Tool used on this step:
    Spudger
    $3.99
    Buy
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  6. Asus Eee PC 1215N Keyboard Replacement, Top Cover (Touchpad): step 6, image 1 of 1
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  7. Asus Eee PC 1215N Keyboard Replacement: step 7, image 1 of 3 Asus Eee PC 1215N Keyboard Replacement: step 7, image 2 of 3 Asus Eee PC 1215N Keyboard Replacement: step 7, image 3 of 3
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
  8. Asus Eee PC 1215N Keyboard Replacement: step 8, image 1 of 2 Asus Eee PC 1215N Keyboard Replacement: step 8, image 2 of 2
    Spudger
    $3.99
    Buy
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
  9. Asus Eee PC 1215N Keyboard Replacement, Keyboard: step 9, image 1 of 3 Asus Eee PC 1215N Keyboard Replacement, Keyboard: step 9, image 2 of 3 Asus Eee PC 1215N Keyboard Replacement, Keyboard: step 9, image 3 of 3
    • Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
    • Remove the keyboard 4 screws on the bottom.
    • Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
  10. Asus Eee PC 1215N Keyboard Replacement: step 10, image 1 of 1
    Spudger
    $3.99
    Buy
    • At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
    • Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
    • The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
  11. Asus Eee PC 1215N Keyboard Replacement: step 11, image 1 of 2 Asus Eee PC 1215N Keyboard Replacement: step 11, image 2 of 2
    Spudger
    $3.99
    Buy
    • Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
    • Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
    • Now you can remove the keyboard.
Gaetan
9,574 Reputation
18 Guides authored
One Comment
Yes, you are right! I will have this added shortly.
Thank you.
Gaetan - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 4,493
