Asus Chromebook Flip C100 Lower Case Replacement
  1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100 Lower Case Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100 Lower Case Replacement: step 3, image 1 of 1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100 Lower Case Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100 Lower Case Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Disconnect the two cables from the motherboard with tweezers
11 other people completed this guide.
One Comment
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 5,125
