Asus Chromebook C300SA-DS02 WiFi Card Replacement
  1. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: step 1, image 1 of 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: step 1, image 2 of 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 2, image 1 of 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 2, image 2 of 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 2, image 3 of 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 3, image 1 of 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 3, image 2 of 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 3, image 3 of 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 4, image 1 of 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: step 5, image 1 of 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: step 5, image 2 of 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 6, image 1 of 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 6, image 2 of 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 7, image 1 of 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: step 8, image 1 of 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: step 8, image 2 of 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: step 8, image 3 of 3
    • Use the spudger to pop the black and white coaxial WiFi cables up from the WiFi card.
  9. Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 9, image 1 of 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement: step 9, image 2 of 2
    • Remove the one 3.6mm Phillips #0 screw from the WiFi card.
    • Pull and lift the WiFi card away from the motherboard.
Sarah Westberg
23,564 Reputation
70 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,628 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 429
