Asus Chromebook C300MA-DH02 Motherboard Replacement
  1. Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: step 1, image 1 of 3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: step 1, image 2 of 3 Asus Chromebook C300MA-DH02 Motherboard Replacement, Keyboard Panel: step 1, image 3 of 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Motherboard Replacement: step 2, image 1 of 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Motherboard Replacement: step 3, image 1 of 2 Asus Chromebook C300MA-DH02 Motherboard Replacement: step 3, image 2 of 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: step 4, image 1 of 2 Asus Chromebook C300MA-DH02 Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
    • Remove the motherboard silver mount.
  5. Asus Chromebook C300MA-DH02 Motherboard Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to remove the connection from sound driver on the bottom left of the motherboard.
  6. Asus Chromebook C300MA-DH02 Motherboard Replacement: step 6, image 1 of 1
    • Gently remove the blue connector to the right side of the motherboard.
  7. Asus Chromebook C300MA-DH02 Motherboard Replacement: step 7, image 1 of 2 Asus Chromebook C300MA-DH02 Motherboard Replacement: step 7, image 2 of 2
    • Use the Phillips #000 Screwdriver to remove the screw on right side of wireless card.
    • Remove the wireless card.
  8. Asus Chromebook C300MA-DH02 Motherboard Replacement: step 8, image 1 of 1
    • Start by lifting tape up off of the connection. Remove the connection to display.
  9. Asus Chromebook C300MA-DH02 Motherboard Replacement: step 9, image 1 of 3 Asus Chromebook C300MA-DH02 Motherboard Replacement: step 9, image 2 of 3 Asus Chromebook C300MA-DH02 Motherboard Replacement: step 9, image 3 of 3
    • Remove (3) three "4mm" screws that connect the hinge to the motherboard using the Phillips #000 Screwdriver.
    • Remove (5) five "4mm" screws around two sides of motherboard using the Phillips #000 Screwdriver.
  10. Asus Chromebook C300MA-DH02 Motherboard Replacement: step 10, image 1 of 1
    • Gently remove motherboard from the Asus Chromebook.
2 other people completed this guide.
Giang Le Nam Dang
149 Reputation
1 Guide authored
USF Tampa, Team S6-G4, Remmell Fall 2017 Member of USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 255
