Asus Chromebook C101P Screen Replacement
  1. Asus Chromebook C101P Screen Replacement, Keyboard: step 1, image 1 of 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Screen Replacement: step 2, image 1 of 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Screen Replacement: step 3, image 1 of 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Screen Replacement: step 4, image 1 of 2 Asus Chromebook C101P Screen Replacement: step 4, image 2 of 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Screen Replacement: step 5, image 1 of 3 Asus Chromebook C101P Screen Replacement: step 5, image 2 of 3 Asus Chromebook C101P Screen Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Screen Replacement, Screen: step 6, image 1 of 2 Asus Chromebook C101P Screen Replacement, Screen: step 6, image 2 of 2
    Buy
    • Detach the the screen cables from the motherboard using a pair of tweezers.
    • Peel off the tape or seal to easily remove the screen cables.
  7. Asus Chromebook C101P Screen Replacement: step 7, image 1 of 2 Asus Chromebook C101P Screen Replacement: step 7, image 2 of 2
    • Remove the Phillips 00 screws from the hinges.
  8. Asus Chromebook C101P Screen Replacement: step 8, image 1 of 1
    • Angle the hinge as shown and use a T5 Torx screwdriver to remove the hinge screws.
  9. Asus Chromebook C101P Screen Replacement: step 9, image 1 of 2 Asus Chromebook C101P Screen Replacement: step 9, image 2 of 2
    • Pry open the hinge by using the iFixit opening tool.
  10. Asus Chromebook C101P Screen Replacement: step 10, image 1 of 1
    • Use the iFixit opening tool to pop out the black rubber grips near the bottom of the screen.
    • Use a Phillips 00 screwdriver to remove the screws beneath the rubber grips.
  11. Asus Chromebook C101P Screen Replacement: step 11, image 1 of 3 Asus Chromebook C101P Screen Replacement: step 11, image 2 of 3 Asus Chromebook C101P Screen Replacement: step 11, image 3 of 3
    • Use the iFixit opening tool to pry around the screen.
    • Use the space between the screen and the hinge to prop it up.
    • Once open, slide the wires that are in the hinge out. The screen should now be fully detached from the case.
Dan Sysopha
345 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 2,069
