Archos Jukebox Recorder 20 Motherboard Replacement
  1. Archos Jukebox Recorder 20 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Motherboard Replacement: step 2, image 1 of 1
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Motherboard Replacement, Button Panel: step 3, image 1 of 1
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Archos Jukebox Recorder 20 Motherboard Replacement: step 4, image 1 of 1
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Archos Jukebox Recorder 20 Motherboard Replacement: step 5, image 1 of 2 Archos Jukebox Recorder 20 Motherboard Replacement: step 5, image 2 of 2
    • Remove the face.
  6. Archos Jukebox Recorder 20 Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Remove four surrounding T5 screws as shown
  7. Archos Jukebox Recorder 20 Motherboard Replacement: step 7, image 1 of 1
    • Remove all four purple bumpers. You may have to bend the metal surround out of the way.
  8. Archos Jukebox Recorder 20 Motherboard Replacement: step 8, image 1 of 1
    • Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
  9. Archos Jukebox Recorder 20 Motherboard Replacement: step 9, image 1 of 2 Archos Jukebox Recorder 20 Motherboard Replacement: step 9, image 2 of 2
    Tool used on this step:
    Desoldering Pump
    $3.99
    Buy
    • Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
  10. Archos Jukebox Recorder 20 Motherboard Replacement: step 10, image 1 of 2 Archos Jukebox Recorder 20 Motherboard Replacement: step 10, image 2 of 2
    • Desolder the remaining two points on the backside of the Jukebox.
    • The Motherboard should now be free from the frame and ready for repair or replacement.
Shaun Rifield
121 Reputation
1 Guide authored
IUPUI, Team S2-G3, Freund Spring 2018 Member of IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 401
