Archos Jukebox Recorder 20 Button Panel Replacement
  1. Archos Jukebox Recorder 20 Button Panel Replacement, Battery: step 1, image 1 of 1
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Button Panel Replacement: step 2, image 1 of 1
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Button Panel Replacement, Button Panel: step 3, image 1 of 1
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Archos Jukebox Recorder 20 Button Panel Replacement: step 4, image 1 of 1
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Archos Jukebox Recorder 20 Button Panel Replacement: step 5, image 1 of 2 Archos Jukebox Recorder 20 Button Panel Replacement: step 5, image 2 of 2
    • Remove the face.
Bryant Bucci
97 Reputation
1 Guide authored
IUPUI, Team S2-G3, Freund Spring 2018 Member of IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 282
