Apple Watch Series 9 Screen Replacement
  1. Apple Watch Series 9 Screen Replacement, Prepare your watch for disassembly: step 1, image 1 of 2 Apple Watch Series 9 Screen Replacement, Prepare your watch for disassembly: step 1, image 2 of 2
    • Before starting this repair, remove your watch from the charger and let its battery drain completely—the watch should shut down from low battery. A charged lithium‑ion battery may catch fire if damaged.
    • Letting the battery drain completely also prevents accidentally turning your watch back on when gripping it during repair.
  2. Apple Watch Series 9 Screen Replacement, Disassembly information: step 2, image 1 of 3 Apple Watch Series 9 Screen Replacement, Disassembly information: step 2, image 2 of 3 Apple Watch Series 9 Screen Replacement, Disassembly information: step 2, image 3 of 3
    • Throughout the rest of your repair:
    • Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
    • To remove a band, firmly press in the small, oval button on the underside of the watch and slide the band out of its groove.
    • Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
  3. Apple Watch Series 9 Screen Replacement, Mark your opening picks: step 3, image 1 of 3 Apple Watch Series 9 Screen Replacement, Mark your opening picks: step 3, image 2 of 3 Apple Watch Series 9 Screen Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your watch. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. Apple Watch Series 9 Screen Replacement, Heat the screen: step 4, image 1 of 1
    • Strong adhesive secures the perimeter of the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the screen for two minutes to soften its adhesive.
    • Alternatively, you can use a hair dryer or heat gun—but be careful as extreme heat can damage the screen and/or battery.
  5. Apple Watch Series 9 Screen Replacement, Insert an iFlex: step 5, image 1 of 3 Apple Watch Series 9 Screen Replacement, Insert an iFlex: step 5, image 2 of 3 Apple Watch Series 9 Screen Replacement, Insert an iFlex: step 5, image 3 of 3
    Tool used on this step:
    iFlex Opening Tool
    $11.99
    Buy
    • The gap between the screen and frame is extremely small. You'll need a thin tool such as an iFlex to create an initial gap.
    • Don't grip the iFlex or similar metal tools by the edges—they're very sharp. Consider wearing gloves to protect your hands.
    • Insert the iFlex at a downward angle between the bottom edge of the screen and frame.
  6. Apple Watch Series 9 Screen Replacement, Pry up the screen: step 6, image 1 of 2 Apple Watch Series 9 Screen Replacement, Pry up the screen: step 6, image 2 of 2
    • Prying up the screen may take multiple attempts. If you're having trouble, apply more heat and try again.
    • With one hand, push down firmly on the watch's frame to secure it in place.
    • With your free hand, hold the iFlex and push the edges up to make it more rigid.
    • The iFlex should be slightly "U" shaped.
    • Pry up the screen enough for the iFlex to lay flat on its own.
    • The iFlex doesn't need to be inserted far, as it can easily damage the screen cables near the bottom right corner of the watch.
    • Leave the iFlex inserted under the screen.
  7. Apple Watch Series 9 Screen Replacement, Insert an opening pick: step 7, image 1 of 3 Apple Watch Series 9 Screen Replacement, Insert an opening pick: step 7, image 2 of 3 Apple Watch Series 9 Screen Replacement, Insert an opening pick: step 7, image 3 of 3
    • Do not insert your opening pick more than 3 mm under the screen when separating the adhesive, as you risk damaging your watches internals.
    • Keep the iFlex flat to maintain a gap between the screen and frame while inserting an opening pick.
    • Insert an opening pick between the screen and iFlex.
    • Remove the iFlex.
  8. Apple Watch Series 9 Screen Replacement, Separate the bottom edge adhesive: step 8, image 1 of 2 Apple Watch Series 9 Screen Replacement, Separate the bottom edge adhesive: step 8, image 2 of 2
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
  9. Apple Watch Series 9 Screen Replacement, Separate the left edge adhesive: step 9, image 1 of 2 Apple Watch Series 9 Screen Replacement, Separate the left edge adhesive: step 9, image 2 of 2
    • Slide the opening pick around the bottom left corner and up the left edge to separate the adhesive.
  10. Apple Watch Series 9 Screen Replacement, Separate the top edge adhesive: step 10, image 1 of 2 Apple Watch Series 9 Screen Replacement, Separate the top edge adhesive: step 10, image 2 of 2
    • Slide the opening pick around the top left corner and along the top edge to separate the adhesive.
  11. Apple Watch Series 9 Screen Replacement, Separate the right edge adhesive: step 11, image 1 of 2 Apple Watch Series 9 Screen Replacement, Separate the right edge adhesive: step 11, image 2 of 2
    • Slide the opening pick around the top right corner and stop at the top of the side button.
    • Don't slide your pick past the side button—you risk damage to the screen cables.
  12. Apple Watch Series 9 Screen Replacement, Separate the remaining adhesive: step 12, image 1 of 2 Apple Watch Series 9 Screen Replacement, Separate the remaining adhesive: step 12, image 2 of 2
    • Insert the long edge of an opening pick between the left edge of the screen and frame.
    • Twist the pick to lift the screen and separate any remaining adhesive.
  13. Apple Watch Series 9 Screen Replacement, Swing open the screen: step 13, image 1 of 3 Apple Watch Series 9 Screen Replacement, Swing open the screen: step 13, image 2 of 3 Apple Watch Series 9 Screen Replacement, Swing open the screen: step 13, image 3 of 3
    • Pull the right edge of the screen over the digital crown.
    • If the screen feels stuck, go back around it with an opening pick to separate any adhesive.
    • Swing up the left edge of the screen so it's upright. The screen should be to the right of the digital crown.
    • During reassembly:
    • This is a good point to plug in your watch and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
    • Follow this guide to apply new screen adhesive and reseal your watch.
  14. Apple Watch Series 9 Screen Replacement, Stand the watch up: step 14, image 1 of 1
    • Flip your watch so the screen is on your workspace and the frame is upright.
    • Keep the screen secured and the frame supported upright for the remaining steps.
  15. Apple Watch Series 9 Screen Replacement, Peel up the screen cable tape: step 15, image 1 of 3 Apple Watch Series 9 Screen Replacement, Peel up the screen cable tape: step 15, image 2 of 3 Apple Watch Series 9 Screen Replacement, Peel up the screen cable tape: step 15, image 3 of 3
    • Use tweezers to peel up the tape covering the two screen cable ZIF connectors.
  16. Apple Watch Series 9 Screen Replacement, Flip up the locking flaps: step 16, image 1 of 3 Apple Watch Series 9 Screen Replacement, Flip up the locking flaps: step 16, image 2 of 3 Apple Watch Series 9 Screen Replacement, Flip up the locking flaps: step 16, image 3 of 3
    • Use the tip of an opening pick to pry up the small, hinged locking flaps on both screen cable ZIF connectors.
  17. Apple Watch Series 9 Screen Replacement, Heat the screen cable: step 17, image 1 of 1
    • Strong adhesive secures the screen cables. Heating the cables softens the adhesive, making them easier to separate.
    • Heat an iOpener and lay it on the screen cables for two minutes to soften the adhesive.
  18. Apple Watch Series 9 Screen Replacement, Separate the screen cable adhesive: step 18, image 1 of 2 Apple Watch Series 9 Screen Replacement, Separate the screen cable adhesive: step 18, image 2 of 2
    • Slide an opening pick under the lower screen cable to begin separating it from the screen.
    • If you're having trouble, apply more heat and try again. Don't use excessive force.
  19. Apple Watch Series 9 Screen Replacement: step 19, image 1 of 3 Apple Watch Series 9 Screen Replacement: step 19, image 2 of 3 Apple Watch Series 9 Screen Replacement: step 19, image 3 of 3
    • Continue sliding the opening pick under the cables until they completely separate from the screen.
    • You can gently peel the cables up with your fingers when you're able to grab them.
  20. Apple Watch Series 9 Screen Replacement, Disconnect the screen: step 20, image 1 of 2 Apple Watch Series 9 Screen Replacement, Disconnect the screen: step 20, image 2 of 2
    • Use tweezers to grip both cables and pull them out of their sockets at the same time.
  21. Apple Watch Series 9 Screen Replacement, Remove the screen: step 21, image 1 of 1
    • Remove the screen.
Spencer Day
53,748 Reputation
394 Guides authored
iFixit Member of iFixit
Staff
135 Members
17,199 Guides authored
0 Comments
Past 24 Hours: 19
Past 7 Days: 97
Past 30 Days: 515
All Time: 1,707
