Apalus Digital Hair Straightening Brush LCD Screen Replacement
  1. Apalus Digital Hair Straightening Brush LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 2, image 1 of 1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 3, image 1 of 1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 4, image 1 of 1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 5, image 1 of 1
    • Locate the LED screen on the top side of the circuit board
  6. Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 6, image 1 of 1
    • Flip the circuit board to start soldering.
  7. Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 7, image 1 of 2 Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 7, image 2 of 2
    • Using the soldering tool, melt the solder holding the LCD screen on the circuit board.
    • The screen is soldered in 11 places on the circuit board. Melt each of these points and remove the screen.
    • Soldering Technique Guide
  8. Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 8, image 1 of 2 Apalus Digital Hair Straightening Brush LCD Screen Replacement: step 8, image 2 of 2
    • Now that the LCD screen is removed, use a soldering tool and solder to install the new screen on the circuit board.
    • Solder at the same 11 points where you previously melted to remove the screen.
Malak
101 Reputation
1 Guide authored
IUPUI, Team S1-G3, Harley Fall 2017 Member of IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 14
All Time: 499
