Aorus X7 v2 RAM Replacement
  1. Aorus X7 v2 RAM Replacement, RAM: step 1, image 1 of 3 Aorus X7 v2 RAM Replacement, RAM: step 1, image 2 of 3 Aorus X7 v2 RAM Replacement, RAM: step 1, image 3 of 3
    Tool used on this step:
    T5 Torx Screwdriver
    $5.49
    Buy
    • First, power off your laptop and unplug all cables and accessories. Then, place it upside down on a stable and flat surface.
    • Use the T5 Torx Screwdriver to remove the 12 screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
    • Locate the two rectangular RAM modules, left and right, in the middle of the motherboard.
    • Gently spread apart the latches on either side for the RAM module to pop up.
  2. Aorus X7 v2 RAM Replacement: step 2, image 1 of 1
    • Carefully remove both RAM modules.
Complete these steps in reverse order to install your new RAM modules.
Alexis Hernandez Jimenez
572 Reputation
5 Guides authored
Gateway, Team 1-4, Pee Fall 2022 Member of Gateway, Team 1-4, Pee Fall 2022
GCC-PEE-F22S1G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 273
