Aorus X7 v2 Motherboard Replacement
  1. Aorus X7 v2 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Aorus X7 v2 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Aorus X7 v2 Motherboard Replacement, Motherboard: step 1, image 3 of 3
    Tool used on this step:
    T5 Torx Screwdriver
    $5.49
    Buy
    • First, power off your laptop and unplug all cables and accessories. Then, place it upside down on a stable and flat surface.
    • Use the T5 Torx Screwdriver to remove the twelve screws on the bottom of the laptop. Once the screws are removed, lift off the bottom panel.
    • Use the Phillips #0 Screwdriver to remove the twelve screws holding the heatsink in place.
    • Carefully pull the two black tabs on either side of the black ribbon to disconnect them from the board.
    • Gently pull off the inner black ribbon to remove it from the board.
    • Use the Phillips #0 Screwdriver to remove the two screws holding the mSATA.
    • With a gently tug, disconnect the four white plugs.
    • Use the Phillips #0 Screwdriver to remove the two screws holding the wireless card.
  2. Aorus X7 v2 Motherboard Replacement: step 2, image 1 of 3 Aorus X7 v2 Motherboard Replacement: step 2, image 2 of 3 Aorus X7 v2 Motherboard Replacement: step 2, image 3 of 3
    • There are three fan plugs to disconnect. In the first photo, locate and disconnect two fan plugs by gently pulling out the black wire from the white plug.
    • Locate and disconnect the third fan plug by gently pulling out the black wire from the white plug.
    • Remove blue ribbon by gently pulling.
  3. Aorus X7 v2 Motherboard Replacement: step 3, image 1 of 3 Aorus X7 v2 Motherboard Replacement: step 3, image 2 of 3 Aorus X7 v2 Motherboard Replacement: step 3, image 3 of 3
    $5.49
    Buy
  4. Aorus X7 v2 Motherboard Replacement: step 4, image 1 of 3 Aorus X7 v2 Motherboard Replacement: step 4, image 2 of 3 Aorus X7 v2 Motherboard Replacement: step 4, image 3 of 3
    $5.49
    Buy
    • Use the Phillips #0 Screwdriver to remove the three screws on the left speaker.
    • Lift the motherboard slightly near the parallel speaker screws to find the orange ribbon underneath. Use the Blunt Nose Tweezer to gently pull it off.
    • In the same area as the blue ribbon, find the orange ribbon and gently pull it off using a pair of needle nose pliers for access to remove the motherboard.
  5. Aorus X7 v2 Motherboard Replacement: step 5, image 1 of 1
    • In the location of the previously removed right speaker, carefully lift off the motherboard.
Complete these steps in reverse order to install your new motherboard.
Alexis Hernandez Jimenez
572 Reputation
5 Guides authored
Gateway, Team 1-4, Pee Fall 2022 Member of Gateway, Team 1-4, Pee Fall 2022
GCC-PEE-F22S1G4
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 510
