Anker SoundCore 2 Motherboard Replacement
  1. Anker SoundCore 2 Motherboard Replacement, Front Panel: step 1, image 1 of 2 Anker SoundCore 2 Motherboard Replacement, Front Panel: step 1, image 2 of 2
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
  2. Anker SoundCore 2 Motherboard Replacement, Motherboard: step 2, image 1 of 3 Anker SoundCore 2 Motherboard Replacement, Motherboard: step 2, image 2 of 3 Anker SoundCore 2 Motherboard Replacement, Motherboard: step 2, image 3 of 3
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
  3. Anker SoundCore 2 Motherboard Replacement: step 3, image 1 of 3 Anker SoundCore 2 Motherboard Replacement: step 3, image 2 of 3 Anker SoundCore 2 Motherboard Replacement: step 3, image 3 of 3
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
Kristen Gismondi
83,158 Reputation
204 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
3 Comments
Where can I buy the C34 and ESD4?
Abel Omeokwe - Reply
Hello.
Do you know where to fond an Anker motherboard please?
Thanks
ckridene - Reply
Princelee Balasingham Prince - Reply
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 55
All Time: 1,348
