Andoer HDV 107 Strap Replacement
  1. Andoer HDV 107 Strap Replacement, Strap: step 1, image 1 of 1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture
    • To open this compartment, apply pressure in the direction of the arrow and remove.
  2. Andoer HDV 107 Strap Replacement: step 2, image 1 of 1
    • Remove the 1 mm circled screws with the Phillips head #000 screwdriver.
  3. Andoer HDV 107 Strap Replacement: step 3, image 1 of 1
    • Remove the 1 mm Phillips head screw.
  4. Andoer HDV 107 Strap Replacement: step 4, image 1 of 1
    • Once all previous screws have been removed the panel can be pulled off of the camera.
  5. Andoer HDV 107 Strap Replacement: step 5, image 1 of 1
    • Use your screwdriver to remove the 1 mm Phillips head screw and release the strap.
Isaac Saron
516 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 153
