View profile
Order History
Logout
Android-based media tablet by Amazon with 7" multi-touch color display.
$29.95 · 50+ in stock
$14.95 · 50+ in stock
$4.95 · 50+ in stock
$4.95 · 23 in stock
$7.95 · 16 in stock
« Back to device
Page 1 of 1
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
PREREQ
With the HTML code below, you can embed this guide as a small widget on your website.
Use the flat end of a spudger to peel the ambient light sensor cable off of the frame.
You will need to peel up the silver tape in the cable's lower right bend. The silver tape under the lower left bend of the cable does not need to come up with it.
Use the flat end of a spudger to peel up the silver tape securing the antenna cable.
Remove the three 3.6 mm Phillips #00 screws securing the frame and ambient light sensor.
For more information, check out the Kindle Fire device page.
Oops, I actually didn't do it.
I did it! Success!
This guide has been completed 0 times.
1024
