Amazon Kindle Fire 7th Generation Battery Replacement
  1. Amazon Kindle Fire 7th Generation Battery Replacement, Battery: step 1, image 1 of 3 Amazon Kindle Fire 7th Generation Battery Replacement, Battery: step 1, image 2 of 3 Amazon Kindle Fire 7th Generation Battery Replacement, Battery: step 1, image 3 of 3
    • Insert the opening tool into the Kindle side.
    • Work around the sides of the device to free all clips.
  2. Amazon Kindle Fire 7th Generation Battery Replacement: step 2, image 1 of 2 Amazon Kindle Fire 7th Generation Battery Replacement: step 2, image 2 of 2
    • Seperate the back panel from the Kindle.
  3. Amazon Kindle Fire 7th Generation Battery Replacement: step 3, image 1 of 2 Amazon Kindle Fire 7th Generation Battery Replacement: step 3, image 2 of 2
    • Remove the two screws securing the battery connector cover using the Phillips #00 screwdriver.
    • Remove the battery connector cover.
    • Put the screws in a safe place, they will be needed later to reconnect the battery cover.
  4. Amazon Kindle Fire 7th Generation Battery Replacement: step 4, image 1 of 2 Amazon Kindle Fire 7th Generation Battery Replacement: step 4, image 2 of 2
    • Disconnect the battery
    • Fit the tip of the plastic opening tool under the bottom right of the battery.
    • Remove the battery from the frame
2 other people completed this guide.
Edgar Palomars
157 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 23
Past 30 Days: 88
All Time: 382
