Amazon Fire HD 8 12th Gen Camera Replacement
  1. Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
    Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: step 1, image 1 of 3 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: step 1, image 2 of 3 Amazon Fire HD 8 12th Gen Camera Replacement, Buttons: step 1, image 3 of 3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
  2. Amazon Fire HD 8 12th Gen Camera Replacement: step 2, image 1 of 2 Amazon Fire HD 8 12th Gen Camera Replacement: step 2, image 2 of 2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
  3. Amazon Fire HD 8 12th Gen Camera Replacement, Camera: step 3, image 1 of 2 Amazon Fire HD 8 12th Gen Camera Replacement, Camera: step 3, image 2 of 2
    • Using the iFixit opening tool, disconnect the battery from the circuit board.
  4. Amazon Fire HD 8 12th Gen Camera Replacement: step 4, image 1 of 3 Amazon Fire HD 8 12th Gen Camera Replacement: step 4, image 2 of 3 Amazon Fire HD 8 12th Gen Camera Replacement: step 4, image 3 of 3
    • Disconnect the camera from the motherboard by unplugging the orange wiring.
    • Heat the area of the back camera up loosening the glue holding it in place.
    • Be careful when using hot tools and removing hot parts.
  5. Amazon Fire HD 8 12th Gen Camera Replacement: step 5, image 1 of 3 Amazon Fire HD 8 12th Gen Camera Replacement: step 5, image 2 of 3 Amazon Fire HD 8 12th Gen Camera Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Once disconnected from the motherboard and heated up, use tweezers to remove the old camera.
Jaden Palmer
485 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 49
