Aluratek ADMPF310F Speakers Replacement
  1. Aluratek ADMPF310F Speakers Replacement, Speakers: step 1, image 1 of 3 Aluratek ADMPF310F Speakers Replacement, Speakers: step 1, image 2 of 3 Aluratek ADMPF310F Speakers Replacement, Speakers: step 1, image 3 of 3
    • Using the plastic opening tool pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Speakers Replacement: step 2, image 1 of 1
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Speakers Replacement: step 3, image 1 of 2 Aluratek ADMPF310F Speakers Replacement: step 3, image 2 of 2
    • Unplug both plugs for the speakers to the motherboard
  4. Aluratek ADMPF310F Speakers Replacement: step 4, image 1 of 2 Aluratek ADMPF310F Speakers Replacement: step 4, image 2 of 2
    • Use plastic opening tool to pull out one of the speakers.
    • Then use your hand to take out the other speaker
  5. Aluratek ADMPF310F Speakers Replacement: step 5, image 1 of 1
    • Disconnect the wires off of the old speakers and solder the old wires onto the new speakers.
Chris Belair
333 Reputation
2 Guides authored
UMass Dartmouth, Team 5-1, Martin Fall 2016 Member of UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 115
