Altair WBP-210 Mini-XLR socket Replacement
  1. Altair WBP-210 Mini-XLR socket Replacement, Remove nut on mini-xlr connector: step 1, image 1 of 1
    • Remove the nut on the mini-xlr connector.
  2. Altair WBP-210 Mini-XLR socket Replacement, Remove corner panels: step 2, image 1 of 1
    • Slide off rubber corner panels holding together the case.
  3. Altair WBP-210 Mini-XLR socket Replacement, Remove case screws: step 3, image 1 of 1
    • If your device has additional screws holding the case together, remove those as well.
    • Not all devices have these screws.
  4. Altair WBP-210 Mini-XLR socket Replacement, Open case: step 4, image 1 of 2 Altair WBP-210 Mini-XLR socket Replacement, Open case: step 4, image 2 of 2
    • Separate the two halves of the case using a suitable tool.
    • Pay attention to the ribbon cable connecting the two halves.
    • The top and bottom panels stay attached to the front of the case.
  5. Altair WBP-210 Mini-XLR socket Replacement, Disconnect Auxiliary Board: step 5, image 1 of 2 Altair WBP-210 Mini-XLR socket Replacement, Disconnect Auxiliary Board: step 5, image 2 of 2
    • Disconnect the Auxiliary Board from the Main Board and put it aside.
  6. Altair WBP-210 Mini-XLR socket Replacement, Remove battery: step 6, image 1 of 2 Altair WBP-210 Mini-XLR socket Replacement, Remove battery: step 6, image 2 of 2
    • Disconnect the battery connector.
    • Gently remove the strip of PCB holding the battery in place.
  7. Altair WBP-210 Mini-XLR socket Replacement, Remove Main Board: step 7, image 1 of 3 Altair WBP-210 Mini-XLR socket Replacement, Remove Main Board: step 7, image 2 of 3 Altair WBP-210 Mini-XLR socket Replacement, Remove Main Board: step 7, image 3 of 3
    • The Main Board is held in place by four PH screws.
    • After removing the screws, gently slide the Main Board out of the main case, together with the top and bottom plates.
  8. Altair WBP-210 Mini-XLR socket Replacement, Replace Mini-XLR4 connector: step 8, image 1 of 3 Altair WBP-210 Mini-XLR socket Replacement, Replace Mini-XLR4 connector: step 8, image 2 of 3 Altair WBP-210 Mini-XLR socket Replacement, Replace Mini-XLR4 connector: step 8, image 3 of 3
    • Desolder the defective connector.
    • It is held in place by 4 pins, no additional pads.
    • Matching replacement part is Switchcraft TRAPC4MSX
    • Amphenol AG4MPCH and Kuilong YA137-2 might fit too.
    • Re-solder the new connector.
  9. Altair WBP-210 Mini-XLR socket Replacement, Assemble lower cover plate.: step 9, image 1 of 2 Altair WBP-210 Mini-XLR socket Replacement, Assemble lower cover plate.: step 9, image 2 of 2
    • Reassemble the lower cover plate.
    • Pay attention to the location of the washer.
    • Tighten the nut on new connector.
When reassembling, take care to only connect the battery after connecting the Auxiliary Board.
raven
1,080 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 24
