Altair WBP-210 Full Disassembly
  1. Altair WBP-210 Full Disassembly, Remove Mini-XLR nut: step 1, image 1 of 1
    • Remove nut on mini-XLR connector.
  2. Altair WBP-210 Full Disassembly, Remove rubber panels: step 2, image 1 of 2 Altair WBP-210 Full Disassembly, Remove rubber panels: step 2, image 2 of 2
    • Slide off rubber panels on all four corners.
    • If there are screws underneath, remove those as well.
  3. Altair WBP-210 Full Disassembly, Open case: step 3, image 1 of 2 Altair WBP-210 Full Disassembly, Open case: step 3, image 2 of 2
    • Open the case using a suitable tool to help separate the two halves.
    • Watch out for the ribbon cable.
  4. Altair WBP-210 Full Disassembly, Remove back case.: step 4, image 1 of 2 Altair WBP-210 Full Disassembly, Remove back case.: step 4, image 2 of 2
    • Disconnect the back half of the case.
  5. Altair WBP-210 Full Disassembly, Remove Auxiliary Board: step 5, image 1 of 2 Altair WBP-210 Full Disassembly, Remove Auxiliary Board: step 5, image 2 of 2
    • There are four screws holding the Auxiliary Board in place.
  6. Altair WBP-210 Full Disassembly, Remove Battery: step 6, image 1 of 2 Altair WBP-210 Full Disassembly, Remove Battery: step 6, image 2 of 2
    • The battery is held in place by a flexible bit of PCB, which can be carefully removed.
  7. Altair WBP-210 Full Disassembly, Remove main board: step 7, image 1 of 2 Altair WBP-210 Full Disassembly, Remove main board: step 7, image 2 of 2
    • The main PCB is held in place by four screws.
raven
1,080 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 32
