Alienware x51 r3 CPU Fan Replacement
  1. Alienware x51 r3 CPU Fan Replacement, CPU Fan: step 1, image 1 of 3 Alienware x51 r3 CPU Fan Replacement, CPU Fan: step 1, image 2 of 3 Alienware x51 r3 CPU Fan Replacement, CPU Fan: step 1, image 3 of 3
    • Lay down the case so that the power button is on the far right corner and is facing your right.
    • Unlock the side panel on the bottom edge by pushing its ridgeline towards the top edge. Lift the panel off of the case.
    • Peel back the cover slowly, as it will still be attached to the case by the cover lights cable. Place the panel against a clean, steady surface in preparation for the next step.
  2. Alienware x51 r3 CPU Fan Replacement: step 2, image 1 of 2 Alienware x51 r3 CPU Fan Replacement: step 2, image 2 of 2
    • Use either your hands or the needle nose pliers to disconnect the cable from its port on the desktop. The lighting cable will still be attached to the case.
    • Safely set down the case lid when ready to move on.
  3. Alienware x51 r3 CPU Fan Replacement: step 3, image 1 of 2 Alienware x51 r3 CPU Fan Replacement: step 3, image 2 of 2
    • Using a #0 Phillips screwdriver, remove the screws connecting the fan cover to the fan by rotating the screwdriver counter-clockwise. Lift the fan cover out of the desktop and place to the side.
  4. Alienware x51 r3 CPU Fan Replacement: step 4, image 1 of 2 Alienware x51 r3 CPU Fan Replacement: step 4, image 2 of 2
    • Using a #0 Phillips screwdriver, remove the screws connecting the fan to the motherboard by rotating the screwdriver counter-clockwise.
    • To prevent bending, try to unscrew each corner a little bit at a time, rather than unscrewing one side completely before moving onto the next.
  5. Alienware x51 r3 CPU Fan Replacement: step 5, image 1 of 3 Alienware x51 r3 CPU Fan Replacement: step 5, image 2 of 3 Alienware x51 r3 CPU Fan Replacement: step 5, image 3 of 3
    • Using either your hands or a small needle nose plier, carefully remove cable connecting the fan to the desktop.
    • Do not rip the cable straight out. Instead, try wiggling the plier back and forth to disconnect.
  6. Alienware x51 r3 CPU Fan Replacement: step 6, image 1 of 3 Alienware x51 r3 CPU Fan Replacement: step 6, image 2 of 3 Alienware x51 r3 CPU Fan Replacement: step 6, image 3 of 3
    • Using your thumb and forefinger, pry off the four clips holding the fan to the heatsink.
  7. Alienware x51 r3 CPU Fan Replacement: step 7, image 1 of 2 Alienware x51 r3 CPU Fan Replacement: step 7, image 2 of 2
    • Place the new or cleaned fan onto the heatsink, and press down on the corners to lock the fan onto the heatsink.
    • Make sure that the fan is positioned to blow air into the heatsink, rather than out.
After installation of the new CPU fan, the user’s computer should run more efficiently.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 33
All Time: 1,460
