Alienware M15-P97F SSD Replacement
  1. Alienware M15-P97F SSD Replacement, SSD: step 1, image 1 of 3 Alienware M15-P97F SSD Replacement, SSD: step 1, image 2 of 3 Alienware M15-P97F SSD Replacement, SSD: step 1, image 3 of 3
    • Shut down your computer by holding the power button for five seconds.
    • Disconnect the computer from all attachments and power sources.
  2. Alienware M15-P97F SSD Replacement: step 2, image 1 of 3 Alienware M15-P97F SSD Replacement: step 2, image 2 of 3 Alienware M15-P97F SSD Replacement: step 2, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the six 2.4 mm screws from the bottom of the computer.
    • Also, remove the two screws located near the base of the power cord.
    • Loosen the three captive screws located closest to the touchpad.
    • Remove the back case.
  3. Alienware M15-P97F SSD Replacement: step 3, image 1 of 2 Alienware M15-P97F SSD Replacement: step 3, image 2 of 2
    • Whenever removing or installing parts. The battery should be disconnected.
    • Disconnect the battery cable from the system board.
  4. Alienware M15-P97F SSD Replacement: step 4, image 1 of 3 Alienware M15-P97F SSD Replacement: step 4, image 2 of 3 Alienware M15-P97F SSD Replacement: step 4, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the single M2x25 screw that secures the solid-state drive.
    • Slide the SSD out from the socket to remove it from the system.
    • Always hold the SSD at the edges.
  5. Alienware M15-P97F SSD Replacement: step 5, image 1 of 3 Alienware M15-P97F SSD Replacement: step 5, image 2 of 3 Alienware M15-P97F SSD Replacement: step 5, image 3 of 3
    • Slide the M.2 2280 solid state drive into the M.2 card slot 2.
    • Slide the M.2 2280 thermal shield onto the frame.
    • Use the Phillips #1 screwdriver to replace the M2x25 screw and secure the SSD.
  6. Alienware M15-P97F SSD Replacement: step 6, image 1 of 3 Alienware M15-P97F SSD Replacement: step 6, image 2 of 3 Alienware M15-P97F SSD Replacement: step 6, image 3 of 3
    • To mount the solid state drive to primary drive go to the disk management setting. Right-click the unallocated drive and then left-click on the new simple volume.
    • You will get prompted with 5 screens:
    • Welcome to the New Simple Volume Wizards: Press “Next".
    • Specify Volume size: Choose the amount of memory you want to allocate (1000Mb = 1GB). Then click “Next”.
  7. Alienware M15-P97F SSD Replacement: step 7, image 1 of 3 Alienware M15-P97F SSD Replacement: step 7, image 2 of 3 Alienware M15-P97F SSD Replacement: step 7, image 3 of 3
    • Assign Driver Letter or Path: Choose “Mount in the following empty NFTS folder” by clicking browse.
    • Now choose what drive to mount to by clicking the drive, it will enable a drop-down list.
    • Find the location on the drive that you find suitable. Then make an empty folder or place it into an empty folder. Then press “OK” then “Next”.
    • Make sure that the “Format this volume with the following settings” option is selected with default settings then click “Next”.
    • To complete the new simple volume wizard, click finish.
To reassemble your device, follow step 3 in reverse order until step 1.
Rachad Quintyne
195 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 25
All Time: 665
