Alienware Aurora M9700 RAM Replacement
  1. Alienware Aurora M9700 RAM Replacement, RAM: step 1, image 1 of 1
    • Turn the laptop over so the bottom of the device is facing upward.
  2. Alienware Aurora M9700 RAM Replacement: step 2, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 2, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 2, image 3 of 3
    • Remove the battery by unlocking the lock.
  3. Alienware Aurora M9700 RAM Replacement: step 3, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 3, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 3, image 3 of 3
    • Located on the top right corner, find the 4 screws that are holding the back plate to the laptop.
    • Once the screws are removed insert the spudger on the right side and pry upwards to lift the plate to remove the plate.
  4. Alienware Aurora M9700 RAM Replacement: step 4, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 4, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 4, image 3 of 3
    • Lift the back plate of the laptop to expose the RAM.
    • Locate the RAM near the bottom edge of the top portion.
  5. Alienware Aurora M9700 RAM Replacement: step 5, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 5, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 5, image 3 of 3
    • The RAM is secured by two aluminum locks on each side.
    • Pull the left-lock to the left to release the RAM.
    • While still holding the left hinge, pull the right-lock to the right and the RAM will be released.
  6. Alienware Aurora M9700 RAM Replacement: step 6, image 1 of 3 Alienware Aurora M9700 RAM Replacement: step 6, image 2 of 3 Alienware Aurora M9700 RAM Replacement: step 6, image 3 of 3
    • Once the RAM is released, pull the RAM out.
    • There may be a second RAM located below the first one, if so repeat step 5.
    • After both RAMS are removed you can now replace or upgrade the RAM.
Jasmine Anchondo
679 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 319
