Alcatel One Touch Elevate (5017B) Motherboard Replacement
  1. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: step 1, image 1 of 3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: step 1, image 2 of 3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Battery: step 1, image 3 of 3
    • Locate the small indent on the lower left corner.
    • Use your fingers or a small plastic opening tool to lift the back cover off.
  2. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 2, image 1 of 3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 2, image 2 of 3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 2, image 3 of 3
    • Locate the indent between the battery and your phone.
    • Use your finger or a small plastic opening tool to lift the battery free.
  3. Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: step 3, image 1 of 3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: step 3, image 2 of 3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement, Motherboard: step 3, image 3 of 3
    • Using the Phillips screw driver, remove the 9 screws from the phone.
  4. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 4, image 1 of 1
    • Using your prying tool, place it between the screen and the back cover and pry it open.
  5. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 5, image 1 of 2 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 5, image 2 of 2
    • Disconnect the camera from the mother board with your prying tool.
  6. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 6, image 1 of 3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 6, image 2 of 3 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 6, image 3 of 3
    • Remove both of this cables located on the bottom left corner of the phone.
  7. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 7, image 1 of 2 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 7, image 2 of 2
    • Remove the volume and power button using your prying tool.
    • Go underneath the bronze plate with your prying tool and carefully pry it off.
  8. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 8, image 1 of 1
    • Remove this pice that is to the right of the camera with your prying tool.
  9. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 9, image 1 of 2 Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Remove this two pieces by using your tweezers.
    • Carefully pull them off. There will be a black flap where you can place your tweezers to pull.
  10. Alcatel One Touch Elevate (5017B) Motherboard  Replacement: step 10, image 1 of 1
    • Using you prying tool, go in-between the phone.
    • Carefully pry it off.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 283
