Adjusting Nishiki Aero II Seat
  1. Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: step 1, image 1 of 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: step 1, image 2 of 3 Adjusting Nishiki Aero II Seat, Adjusting Nishiki Aero II Seat: step 1, image 3 of 3
    • Loosen the bolt that secures your seat.
    • To do so, use one wrench to hold the larger nut on the left side of the bike still while you loosen the nut on the right.
  2. Adjusting Nishiki Aero II Seat: step 2, image 1 of 2 Adjusting Nishiki Aero II Seat: step 2, image 2 of 2
    • Now that it can move, move the seat by wiggling it and pulling it in the direction you want to adjust it.
    • You want to the adjust the seat so that, when a pedal is at the far end of its rotation, your leg is fully extended.
    • Don't worry about getting it perfect on the first try. Instead, guess your adjustment, tighten the bolt a little bit, try it out, and adjust again until you get it right.
  3. Adjusting Nishiki Aero II Seat: step 3, image 1 of 1
    • Once your seat is at the desired height, you just tighten the bolt the same way you loosened it.
    • Use two wrenches, one to hold it still and the other to tighten the nut.
    • Make sure it's very tight, or else the seat might twist or lower over time.
Tobias Elder
113 Reputation
7 Guides authored
Cal Poly, Team 21-53, Johann Spring 2013 Member of Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 30
All Time: 2,780
