Acer One 10 S1003-114M Track Pad Replacement
  1. Acer One 10 S1003-114M Track Pad Replacement, Track Pad: step 1, image 1 of 1
    • Open the screen.
  2. Acer One 10 S1003-114M Track Pad Replacement: step 2, image 1 of 1
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Track Pad Replacement: step 3, image 1 of 2 Acer One 10 S1003-114M Track Pad Replacement: step 3, image 2 of 2
    • Turn over the keyboard and use the plastic pry tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Track Pad Replacement: step 4, image 1 of 3 Acer One 10 S1003-114M Track Pad Replacement: step 4, image 2 of 3 Acer One 10 S1003-114M Track Pad Replacement: step 4, image 3 of 3
    • Remove ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Track Pad Replacement: step 5, image 1 of 1
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Track Pad Replacement: step 6, image 1 of 1
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Track Pad Replacement: step 7, image 1 of 1
    • Use an opening tool to remove/peel off the adhesive tape from the trackpad electrical connector
  8. Acer One 10 S1003-114M Track Pad Replacement: step 8, image 1 of 2 Acer One 10 S1003-114M Track Pad Replacement: step 8, image 2 of 2
    • Use an opening tool to flip/pop the switch holding down the electric connector to the keyboard.
  9. Acer One 10 S1003-114M Track Pad Replacement: step 9, image 1 of 2 Acer One 10 S1003-114M Track Pad Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Use the fine tip tweezers to remove the electrical connector for the trackpad. Pull gently.
  10. Acer One 10 S1003-114M Track Pad Replacement: step 10, image 1 of 3 Acer One 10 S1003-114M Track Pad Replacement: step 10, image 2 of 3 Acer One 10 S1003-114M Track Pad Replacement: step 10, image 3 of 3
    • To free the retainer, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  11. Acer One 10 S1003-114M Track Pad Replacement: step 11, image 1 of 1
    • To free the trackpad, remove the 2 mount screws, 3.50mm length and 4.90mm diameter heads, with a Phillips #0 screwdriver.
  12. Acer One 10 S1003-114M Track Pad Replacement: step 12, image 1 of 1
    • Use a pair of fine tip tweezers to remove the adhesive metallic strap holding the trackpad to the keyboard.
  13. Acer One 10 S1003-114M Track Pad Replacement: step 13, image 1 of 1
    • Gently remove the trackpad from the keyboard.
Karan Karthik
217 Reputation
1 Guide authored
IUPUI, Team S2-G6, Harley Spring 2019 Member of IUPUI, Team S2-G6, Harley Spring 2019
IUPUI-HARLEY-S19S2G6
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 25
All Time: 757
