Acer One 10 S1003-114M Screen Hinge Replacement
  1. Acer One 10 S1003-114M Screen Hinge Replacement, Screen Hinge: step 1, image 1 of 1
    • Open the screen.
  2. Acer One 10 S1003-114M Screen Hinge Replacement: step 2, image 1 of 1
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Screen Hinge Replacement: step 3, image 1 of 2 Acer One 10 S1003-114M Screen Hinge Replacement: step 3, image 2 of 2
    • Turn over the keyboard and use the plastic opening tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Screen Hinge Replacement: step 4, image 1 of 3 Acer One 10 S1003-114M Screen Hinge Replacement: step 4, image 2 of 3 Acer One 10 S1003-114M Screen Hinge Replacement: step 4, image 3 of 3
    • Remove the ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Screen Hinge Replacement: step 5, image 1 of 1
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Screen Hinge Replacement: step 6, image 1 of 1
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Screen Hinge Replacement: step 7, image 1 of 2 Acer One 10 S1003-114M Screen Hinge Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the electrical connector for the hinge. Pull gently while wiggling the connector back and forth.
    • Remove the adhesive tape holding the wire down.
  8. Acer One 10 S1003-114M Screen Hinge Replacement: step 8, image 1 of 2 Acer One 10 S1003-114M Screen Hinge Replacement: step 8, image 2 of 2
    • To free the hinge, remove the 4 mount screws with a Phillips #0 screwdriver.
  9. Acer One 10 S1003-114M Screen Hinge Replacement: step 9, image 1 of 2 Acer One 10 S1003-114M Screen Hinge Replacement: step 9, image 2 of 2
    • Remove the disconnected hinge from the keyboard.
6 other people completed this guide.
Justin Bawinkel
327 Reputation
1 Guide authored
IUPUI, Team S2-G6, Harley Spring 2019 Member of IUPUI, Team S2-G6, Harley Spring 2019
IUPUI-HARLEY-S19S2G6
4 Members
2 Guides authored
5 Comments
Where can I buy the hinges of acer one 10 D16H1?
ladysam020889 - Reply
Do you know where I can find hinges of acer one s1003?
Al Monslisa - Reply
The hinge is so stiff it broke off the keyboard tabs. I need to loosen the hinge and replace the keyboard base, or hopefully just the positioning tabs (if they can be reglued).
PGI Cruiser - Reply
Tutoriel bien expliqué, merci pour tout, vous m’avez bien aidé à changer la charnière moi-même.
Francis Meylemans - Reply
Where can i buy new hinge for acer one s1003 , plss suggest me
Arvind - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 44
All Time: 6,268
