Acer Iconia One 10 B3-A30 Repair Screen Replacement
  1. Acer Iconia One 10 B3-A30 Repair Screen Replacement, Battery: step 1, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Battery: step 1, image 2 of 2
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 2, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 2, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 2, image 3 of 3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 3, image 1 of 1
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 4, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 4, image 2 of 2
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 5, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 5, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 5, image 3 of 3
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Acer Iconia One 10 B3-A30 Repair Screen Replacement, Motherboard: step 6, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Motherboard: step 6, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Motherboard: step 6, image 3 of 3
    • Remove all of the tape surrounding the motherboard.
  7. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 7, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 7, image 2 of 2
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 8, image 1 of 1
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 9, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 9, image 2 of 2
    • Using the small plastic tool, carefully pry the motherboard out of the device.
  10. Acer Iconia One 10 B3-A30 Repair Screen Replacement, Screen: step 10, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Screen: step 10, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement, Screen: step 10, image 3 of 3
    • Using a plastic spudger pry the square connection away from the screen.
  11. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 11, image 1 of 1
    • Using the Philips #00 head unscrew the screw holding in the small plate.
  12. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 12, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 12, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 12, image 3 of 3
    • Using the Philips #00 unscrew the remaining 4 screws along the two speakers.
  13. Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 13, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Screen Replacement: step 13, image 2 of 2
    • Using the plastic spudger gently pry the screen along the plastic clips.
    • Once at least 1/2 of the screen is unclipped slide it out of the frame using hands.
14 other people completed this guide.
Austin Pickart
688 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Nance Fall 2017 Member of USF Tampa, Team S1-G5, Nance Fall 2017
USFT-NANCE-F17S1G5
4 Members
5 Guides authored
11 Comments
nice job people!
Johnathon Ferland - Reply
It worked! I’m very happy
marmaesker - Reply
nice job
Linh Pham
Linh Pham - Reply
This helped out a lot, thanks
feje75 - Reply
Fantastic set of instructions. Very much appreciated. Cheers very much!!
Chris Wilson - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 12,822
