Acer Iconia One 10 B3-A30 Repair Power Switch Replacement
  1. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Battery: step 1, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Battery: step 1, image 2 of 2
    • Make sure the device is powered off.
    • Open media port cover at the top of the tablet.
    • Use the Phillips #00 screwdriver to remove the 1 mm screw.
  2. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 2, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 2, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 2, image 3 of 3
    • Using the metal spudger, carefully pry open the back cover.
  3. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 3, image 1 of 1
    • Remove small section of grey tape.
  4. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 4, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 4, image 2 of 2
    • Unplug the connection cord from the motherboard.
  5. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 5, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 5, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 5, image 3 of 3
    • Try to remove the battery by pulling on the blue tabs.
    • If unsuccessful, use the black plastic spudger to gently break the glue bonds underneath and pull up to remove the battery.
    • Be very cautious not to puncture or bend the battery.
  6. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: step 6, image 1 of 3 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: step 6, image 2 of 3 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Motherboard: step 6, image 3 of 3
    • Remove all of the tape surrounding the motherboard.
  7. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 7, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 7, image 2 of 2
    • Starting with the 2 large connections use the plastic opening tool to gently pry on the connections and pop them out.
    • Now, disconnect the two smaller black and red cords from the motherboard.
  8. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 8, image 1 of 1
    • Scrape away the small square sticker to reveal one small screw. Use the Phillips #00 screwdriver to remove the screw.
    • Using the same screwdriver remove the other three screws on the motherboard.
  9. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 9, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement: step 9, image 2 of 2
    • Using the small plastic tool, carefully pry the motherboard out of the device.
  10. Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Power Switch: step 10, image 1 of 2 Acer Iconia One 10 B3-A30 Repair Power Switch Replacement, Power Switch: step 10, image 2 of 2
    • Depress power switch using finger, and simultaneously pry in same direction with a plastic opening tool.
Austin Pickart
688 Reputation
5 Guides authored
USF Tampa, Team S1-G5, Nance Fall 2017 Member of USF Tampa, Team S1-G5, Nance Fall 2017
USFT-NANCE-F17S1G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 1,992
